Results 1 to 5 of 5
    Nov 2016
    Default astra H REC pin od dump
    astra H REC pin od dump Thank you
    ------------ 5935--------------
  3. The Following User Says Thank You to drahe For This Useful Post:
    tomxx (26th April, 2018)
    Nov 2016
    thanks but the pin is bad
    Nov 2016
    correct pin it 5979
    Nov 2016
    Thanks Drache, your code is good, I confused myself, I had two rec
  7. The Following User Says Thank You to tomxx For This Useful Post:
    drahe (4th July, 2018)
