Corsa MJD603.S3
Results 1 to 5 of 5
Thread: Corsa MJD603.S3
    Sep 2016
    Default Corsa MJD603.S3
    Hi all, Have a 1.3 cdti corsa in my shop with water damaged ecu Magneti Marelli MJD603.S3 , Customer bought a second hand ecu and instructions with ecu is to programme to car. Ive tried with opcom and keep getting P1614 and B3977 fault codes. i can erase and re programme the water damaged ecu without a problem. I have read 95320 eeprom from the second hand customer supplied ecu and will attach it here. I have tried to write the original eeprom read to donor but it doesnt accept it. Hope someone can help
    Bllinda's Avatar
    Baltic
    Where is the original .... This moisture is damaged.
    Quote Originally Posted by RexRonaldo View Post
    .... Ive tried with opcom and keep getting P1614 and B3977 fault codes. i can erase and re programme the water damaged ecu without a problem. I have read 95320 eeprom from the second hand customer supplied ecu and will attach it here. I have tried to write the original eeprom read to donor but it doesnt accept it. Hope someone can help
    today
    A topic that interests me
    Sep 2016
    Thank you Bllinda for your time, here attached is the original read from the water damaged ecu. Above is the read from the second hand ecu which is to be installed.
    Bllinda's Avatar
    Baltic
    Question new ecu p/n 55568383 KZ ?
    ​try .... ....
    today
  5. The Following User Says Thank You to Bllinda For This Useful Post:
    RexRonaldo (26th April, 2018)
    Sep 2016
    Perfect Bllinda could I have the password please.
