No. Remote syncs same time when immo.is programmed.
Hi all i add remote key bu dump
Cas3 2010 e60.
Cas3 needs downgrade..i try with abrites but it wouldn't downgrade....
So i add by dump ..car starts but remote wont work...
Is there anyway i can syncro remote?
Thanks.
Sent from my SM-G935F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
1. Is there any working remote key now?
2. Do you have proper remote frequency?
Hi.
Job was for spare key.
I buck up cas3 first.
Then try to do key by obd with abrites.
Cas3 is istap45+ need downgrade.
Did try to downgrade but avdi is stuck at10%when reading flash.so i cant do it by obd so far.
So i try to program key by dump.
Ori key works ok as it was working.
New key only starts car but remote not work.
I check frequency and its ok. Booth keys 868.
