hello
file winols first adjustment customer not satisfied.
ori file mod second adjustment customer not satisfied.
ori file mpc orginal file
this 2 file it good tuned?
how much horsepower?
help please
regards
hello
help please
regards
where is the file?
For correct tunning file you need disable Torque Monitoring
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
SEE YOU FILE?
HELLO LARAVAG
disable Torque Monitoring, is not happening?
regards
post your ori also if you need some help to check,
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
I do tomorrow
I've done
all files are post here
Thanks act tuning
I checked your file, too much missing maps, and check your duration map as you make it in opposite, just by raise duration and boost not make more power on factory ecus, and good for you it not working, bad boost map,duration. this mod will not make power at all.
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
Hi Thanx
2 file bad ?
Winols and MOD?
