Results 1 to 15 of 19
    DUPNICA BULGARIA
    Default GOLF 6 MM5 km ERROR
    Hi to all. Cluster is 5K0920871A Magneti Marelli. When i ewitsh on dash shows error after 4 sec km. come up. This is flash (nec) and eeprom. If someone can fix eeprom or have nec dump + 95320 dump.Thanks.
    Mar 2013
    check all led diode in dash lot of time error is because dead led diode good luck
    Nov 2011
    Macedonia
    Default fix flesh
    Quote Originally Posted by ilian_cho View Post
    write only this flesh
    Baze007
  4. The Following 2 Users Say Thank You to baze007 For This Useful Post:
    ilian_cho (27th April, 2018), kamelkamel (24th February, 2019)
    brend's Avatar
    Oct 2015
    Same where
    If nothing helped,check led like ABS,SRS,ECU,.........
    If same broken ,its to do this problem to.
    Just experience.
  6. The Following User Says Thank You to brend For This Useful Post:
    DUPNICA BULGARIA
    Thanks baze007 work fine.
  8. #6
    DUPNICA BULGARIA
    After ignition on off gain error.
  9. #7
    Sep 2015
    Try to write this eeprom
  10. The Following User Says Thank You to sendreq For This Useful Post:
  11. #8
    brend's Avatar
    Oct 2015
    Same where
    Check warning led/smd
  12. #9
    Nov 2011
    Macedonia
    Quote Originally Posted by brend View Post
    it's good that you say (led missing make error on dashboard)... we just have to know how the problem is made .... whether it's a change to km or something else
    if someone tried to change the km of a possible error on the instrument
    Baze007
  13. #10
    DUPNICA BULGARIA
    Thank you sendreq. I try this solution from Xtool. Nothing. I start indicator test with vag-all leds work.
  14. The Following User Says Thank You to ilian_cho For This Useful Post:
    brend (27th April, 2018)
  15. #11
    Sep 2015
    Did you try to use the SMOK solution with flash update?
    If not, here is updated flash
  16. #12
    brend's Avatar
    Oct 2015
    Same where
    if someone tried to change the km of a possible error on the instrument ...............Yes,But after this turn ignition and error up first not this .....When i ewitsh on dash shows error after 4 sec km. come up........
    If km show 4sek , its mean km algoritm right.If not ,nothing show......
    Quote Originally Posted by baze007 View Post
  17. #13
    brend's Avatar
    Oct 2015
    Same where
    Fault code in dash ?
  18. #14
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    error in volkswagen dash we fix with reading dash eproom or ecu eproom ?
  19. #15
    DUPNICA BULGARIA
    error code -check sum error
