Results 1 to 15 of 15
    Top Poster Kinred's Avatar
    Oct 2015
    In the Jungle
    Default Vw Suran p1609 steering crash
    Hi i need clear this fault p1609 on steering column after crash on vw suran brazil
    5Z1909144D
    thank you
    Thank You
    Oct 2015
    In the Jungle
    no solution ?
    Thank You
    autoelite's Avatar
    olá. houvi dizer que o escanner da napro faz este ajuste básico.
  4. The Following User Says Thank You to autoelite For This Useful Post:
    Kinred (3rd May, 2018)
    try this one,no thanks and rep =No pass
    All my posts are basically communication and help for others, and it's always free. It takes a lot of energy and time, so don't forget the feedback
  6. The Following 2 Users Say Thank You to kolocar For This Useful Post:
    Kinred (29th April, 2018), mazolatech (4th June, 2022)
    Ukraine
    Reset to factory settings will help you.
  8. The Following User Says Thank You to Vladimir.zheurov For This Useful Post:
  9. #6
    Oct 2015
    In the Jungle
    Quote Originally Posted by kolocar View Post
    cant work mate p1609 is present
    Thank You
  10. #7
    fix now ,try and report,pass is same
  11. The Following User Says Thank You to kolocar For This Useful Post:
    Kinred (4th May, 2018)
  12. #8
    Oct 2015
    In the Jungle
    this is the return of first file tested
    Thank You
  13. #9
    Oct 2015
    In the Jungle
    hi kolocar need a good solution the car is 50km to test and on bench not diag without dashboard
    Thank You
  14. #10
    Oct 2015
    In the Jungle
    i solved this on dealer 15 minutes of work
    Thank You
  15. #11
    Argentina CABA
    Hi, i have error code P1609, vw suran, need pin code or repair dump!, or dump original ok... Thanks....
  16. #12
    pioneer427's Avatar
    Feb 2017
    Belarus
    Try login 17580(20103)
    Adaptation (10)
    chahel 00
    test-save
  17. #13
    Argentina CABA
    Hi Pioneer427, no found the pin login: 17580, 20103...
  18. #14
    Oct 2015
    In the Jungle
    hi i need to solve p1609 via dump someone has the solution???
    Thank You
  19. #15
    Feb 2018
    Could you send the pass im my PM? I already gave your reputation and thanks
