Results 1 to 7 of 7
    Apr 2018
    California
    Default Airbag dump portability
    I was wondering if cleared crash data would work on any car of the same model/year as the wrecked one.
    What would happen if you did use cleared data from another car?
    How do you know what data to erase?
  2. The Following User Says Thank You to busio For This Useful Post:
    Herme (31st July, 2018)
  3. #2
    Depends
    The model number of srs need to match also you will probable have to program to car i:e chassis numbers different or proxy alignment ect
    Apr 2018
    California
    I figured as much.
    How do you know what to erase in the dump file?
    Are there any clues or do you need a clean dump to see the largest chunk of different data?
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    You should have an ori dump and a dump with crash data.
    then you compare and you see what is changed.
    Or you can buy carprog that can erase crash data,you save both of the files(with and without crash)
    then you compare them again!
    Apr 2018
    California
    Quote Originally Posted by Stelaras26 View Post
    I see, so if you find where crash data it will be in the same place for any car of the same year and model as the one you compared the data right?
    My car is already wrecked so I can't do that.
    I've looked for the model here and found posts where people are getting their data cleared but I can't download the files to compare them.
    I tried removing the srs module from my car but it's stuck on tight so the bolt is getting stripped.
    Jun 2016
    Quote Originally Posted by busio View Post
    Good Going keep it up
    We make A
    Living by
    What we get,
    but we make a
    life
    by
    What we give.
    -Winston Churchill
    Jan 2016
    tbilisi
    you need to buy special calculators for it.
