Page 1 of 3 123 LastLast
Results 1 to 15 of 45
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Default Mazda 6 Bose amp fault
    not radio code but radio related .
    Does anyone know the cause of the machine gun sound that the amp produces when faulty
    regards
  2. The Following User Says Thank You to teerak2uk For This Useful Post:
    Meat-Head (14th August, 2019)
  3. #2
    gapco's Avatar
    Jan 2012
    Johannesburg,South Africa
    The solution for the amplifier. Tell us if this worked.
  4. The Following 2 Users Say Thank You to gapco For This Useful Post:
    rsar7607 (14th February, 2022), teerak2uk (1st May, 2018)
  5. #3
    Apr 2008
    boserepairexperts.eu
  6. #4
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by badne55 View Post
    Thanks but trying to repair it for a friend so want to keep the costs down
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by gapco View Post
    Just changed the larger chip but unfortunately have no sound now
  8. The Following User Says Thank You to teerak2uk For This Useful Post:
    sikastag (21st March, 2019)
  9. #6
    gapco's Avatar
    Jan 2012
    Refer to my notes and replace both components.
  10. #7
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    yes still waiting for the part to come but was curious why machine gun sound but no sound at all after changing only 1 of the chips
  11. #8
    Romania
    Look here :measuring this voltages,If stabilizer ST2L05-3300 ( 1,25V ) not working good ,it can destroy the DSP.
    If the stabilizer is changed and the DSP also changed ,and still not working then must change the CS42438 also.
    You can visualized the stabilizer voltage with oscilloscope.
    Send us results.
  12. The Following 13 Users Say Thank You to attilaa0 For This Useful Post:
    bidu20 (25th June, 2018), BusCan (4th November, 2021), carprotech (29th April, 2021), lwd11 (2nd September, 2020), Mezz_cro (25th July, 2018), rsar7607 (14th February, 2022), shooting (28th May, 2018), sigitbintara (21st June, 2022), sikastag (21st March, 2019), sonices (29th May, 2018), teerak2uk (29th May, 2018), TERNOCOD (31st October, 2019)
  13. #9
    gapco's Avatar
    Jan 2012
    Quote Originally Posted by teerak2uk View Post
    yes still waiting for the there art to come but was curious why machine gun sound but no sound at all after changing only 1 of the chips
    Attilla0 has replied with good information. I suggest you buy another DSP chip as you probably damaged it.
  14. The Following 2 Users Say Thank You to gapco For This Useful Post:
    attilaa0 (28th May, 2018), teerak2uk (29th May, 2018)
  15. #10
    Romania
    First change the stabilizer and do not solder the DSP,check the voltages 1,25V and 3,3V also and check also with oscilloscope ,the line must be stable without any noise when visulizing with scope,if it's ok only after that solder the new DSP.And if still not work then change the CS42438.
  16. The Following 3 Users Say Thank You to attilaa0 For This Useful Post:
    asto (13th July, 2020), sonices (29th May, 2018), teerak2uk (29th May, 2018)
  17. #11
    bidu20's Avatar
    Jun 2016
    i repaired one with no tone. the solution from attilaa0 works. I replaced all 3 components
  18. The Following User Says Thank You to bidu20 For This Useful Post:
    audiopoint (25th June, 2018)
  19. #12
    Aug 2010
    Hi everybody! Can you plz share a dump for 24LC256? my amp's DSP does restart 13 times a second, because DSP issues no watchdog signal to voltage regulator, thus the regulator forces reset. I had a look at EEPROM and there were almost only FF's, and, because DSP starts from EEPROM, I'm sure the dump might be damaged.
  20. #13
    Romania
    Hi!I don't know what model you have,i have 2 different dump.Trie it and send me result.
  21. The Following 2 Users Say Thank You to attilaa0 For This Useful Post:
    asto (13th July, 2020), sonices (21st June, 2019)
  22. #14
    Jun 2019
    Hello guys, I have the same problem as OP. I wanted to order replacement chips, but the ones I find on eBay/AliExpress are with different numbers. But does it even matter? Please see image.
  23. #15
    Romania
    Quote Originally Posted by rainy1505 View Post
    Hi!You can order ,it matter only ST2L05-3300 .(9Y 743 not matter)
    CS42438 is the other chip =(can't read anything from this)
    DSPB56374AE or SCB56374AEB is same
  24. The Following 2 Users Say Thank You to attilaa0 For This Useful Post:
    Fresk29 (1st November, 2020), rainy1505 (14th August, 2019)
