Results 1 to 4 of 4
    Mar 2010
    142
    Downloads
    21
    Uploads
    Default Anyone know the right place to kick a Miele Washing machine?
    Had a brilliant week. First my combi packed up then my 2 1/2 year old Miele washing machine.
    The story so far .....
    The Mrs started the washing machine not knowing I was going to turn the water off.
    Half way through a wash a message appeared " CHECK WATER INLET" and the washer kept beeping.
    Turn off the washer to stop the beep.
    Turn the water back on.
    Turn the washer back on - totaly dead!
    Take top off washing machine, continuity from 3 pin plug to washing machine board plug.
    Switch on front of machine makes my multimeter "beep" for continuity when pressed.
    Search on D.K. - nothing
    Search google, youtube - nothing that works, prob because its not for my model of machine.
    Put on hold while I nail a new boiler in.
    1 roll of gaffer tape and a tube of super glue later boiler in.
    I suspect there is a reset sequence to reboot te washing machine but at the moment total dead.
    Miele W3370 if anyone can help.
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    OFF TOPIC:-
    hotpoint same shit diff day, select "drain/pump out"
    press hold "start cancell" until your thumb turns blue or lights go out.
    OFF TOPIC:
    simular thing with hotpoint, so once every so often slam door for lock to engage
    OFF TOPIC:-
    hitpoint needs circuit through motor brushes to power door lock
    ON TOPIC:-
    use sd your free phone calls to call their customer services, record call
    and have another person taking notes, nothing to loose
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    albertros (4th May, 2018)
    Mar 2010
    142
    Downloads
    21
    Uploads
    Thanks Meaty.
    Did as you suggested.
    Told to unplug machine, open and slam close door. plug in and press "on"
    No joy.
    I said I was a little puzzled she hadn't asked which model I had.
    She said it works for all models.
    But the good news is that she can get an engineer out for 120 for the first hour then 75 per hour after that, plus any parts (which he wont have, meaning a second vist)
    Think I'll take out the board and resolder, swap a few relays round, works on Scenic dash boards.
    Morel of the story, Sometimes you have to talk to the Mrs ( reserve my view on listening to the Mrs)
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    Ok, "play on words" turn off at wall, hold on, turn mains on
    and /or google them words see what happens.
    as its after midnight, no admin, so will see if can get away with mentioning
    an "fantastic" (dk million times better) website, if nobody helps you there, open door and chuck it out.
    something like "www.INFERIOR.ukwhitegoods.INFERIOR.UK.STILL.INFER IOR"
    dk rules do state no linking to INFERIOR sites.
