    Mar 2016
    Italy
    Default CORSA D TPMS RETROFIT
    Dear friends,
    here I attach a guide on how to retrofit the TPMS system on a Corsa D.
    Hope it can be useful to anybody.
    Enjoy
  2. The Following 2 Users Say Thank You to uranio00 For This Useful Post:
    Dunker (3rd May, 2018), goncaljo (15th November, 2020)
  3. #2
    Dunker's Avatar
    Yorkshire
    I spend half my time taking TPMS off vehicles. Why would anyone want to add something that causes as much bother.
    Good post though.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Mar 2016
    Italy
    Hello Dunker and thanks for the appreciation!
    I believe that TPMS system is very useful.
    I'm not so careful to check on the tyre pressure sistematically and I have had some bad experience with tyres that have loss enough pressure to become unstable but still not visible at a naked eye.
    On the other car of mine I have installed those universal TPMS systems, with inner wheel valves and the small display.
    It's two years that is perfectly working, with none a single false alarm.
    Everytime it has sent an alert, was for a real good reason.
    So I decided to install it on the Corsa D as well.
    What kind of problem did you have with your TPMS system?
    Dunker's Avatar
    Yorkshire
    Not me personally but many customers of mine ask me to remove TPMS due to the extortionate cost of the valves. To be fair now I think the newer TPMS systems that monitor from the tyre circumfetence from relative wheel speeds from the ABS are a far better idea.
    Dec 2018
    Is it not possible to just enable DDS then.DDS will tell you a wheel is deflating while TPMS system will tell you which wheel.But if there is no way of displaying the pressures it will not be able to tell what wheel is deflating anyway and then the DDS system is just as good.
    Nov 2020
    Portugal
    Very useful information. Thank you
