Results 1 to 11 of 11
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default megane electric handrake fault please explain
    Hi.
    Got scenic parking not work no led on button in car.
    Ive checked all fuses plug under driver seat and 3 thick wires under car to module.
    Two 12v feed and ground good.
    Is there more feed or ground wires to module under car?
    Also module under car turns on led inside car?
    How this system is working?
    Also used module replaced but still not work
    Renault ECU tool / IO terminal / A.S.W
    Apr 2010
    Gdansk Poland
    check dtc if module comunikate ok.
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Wikl check
    drugowaz's Avatar
    Mar 2015
    Lithuania
    No communication with parking module and abs module.
    Also on dash no message that parling brake not work. Only abs message.
    Apr 2010
    Gdansk Poland
    all fuse and ralay checked?? Under engine fusebox checked??
    check +/- to abs in abs plug
    drugowaz's Avatar
    Mar 2015
    Lithuania
    All fuses checked. In all fuseboxes.
    Can not working abs cause parking brake not work?
    Apr 2010
    Gdansk Poland
    today i have espace with unplaged abs parking brake work ok. with dtc but work
    you must find visu for megane and test all wires.
    Dunker's Avatar
    Yorkshire
    Scope CAN waveforms @ EPB plug. Also make sure the power feeds to module can supply enough current. Digital meters will show you voltage at the EPB plug but are you testing voltages when they are under load.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  9. The Following User Says Thank You to Dunker For This Useful Post:
    tvzmaj (10th May, 2018)
  10. #9
    Aug 2011
    Spalding
    Has this got a multi plug under the passengers seat that's full of corrosion?
  11. The Following User Says Thank You to MJRVR For This Useful Post:
    shafo (19th May, 2018)
  12. #10
    drugowaz's Avatar
    Mar 2015
    Lithuania
    This crappy car. Who will pay to me if o start playing with scopes etc
  13. #11
    Dunker's Avatar
    Yorkshire
    Takes 5 minutes to connect and look at CAN waveforms to see if they are distorted. If not willing to test waveforms and power supplies properly why take it in for repair.
