Results 1 to 5 of 5
    Dec 2016
    Default Opel Meriva 1.7 CDTi 101 PS need oryginal file
    Hi!
    I need oryginal file to OPEL MERIVA 1.7 CDTi 101 PS
    HW: 012BE10671
    SW:
    AT26NCLMP60T
    Sw upgrade:
    760MK8SI
    Thanks in advance!!!!
    Kuba
    >>Genuine Winols, Swiftec, Ktag, Flex, x17<<
    >Diagnostic, Chiptuning, Dashbord<
    Sep 2016
    sps by obd to 5 minutes
    FILE SERVICE
    Dec 2016
    @voltecar i do not understand what you mean can, you explain?
    I have this car with bad made DPf Off made not by me....
    This car shows flashing glow plug idicator on the dash, and jumping idle speed I cannot diagnose it without oryg file.
    No dtc stored. Exhaust temp 1&2 ok,
    have disconnected temp sensors, the same.
    Have disconnected dpf pressure sensor nothing change only one more dtc and check engine.
    Maf shows good values
    Probably this flashing glow plug light means sth. But have same dtc deleted from table and cannot see what is wrong with car. Therefore need oryg to diagnose and make proper DPF off.
    Wysłane z mojego STF-L09 przy użyciu Tapatalka
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Kubus whatsapp.
    DSG TUNING
    File Service
  5. The Following User Says Thank You to maajkii For This Useful Post:
    kubuswujo (6th May, 2018)
    Sep 2016
    opel globaltis, use option sps and flashing orginal file this ecu, than read flash edit and write.
    FILE SERVICE
  7. The Following User Says Thank You to voltechcar For This Useful Post:
