Results 1 to 15 of 18
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default laguna 2 button vs 3 button
    Can i use 2 button card insted 3 butyon. The one with light symbol
    topclef's Avatar
    no , you cannot use it , because the Card reader is not the same ( 3 button hand free ) .
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  3. The Following User Says Thank You to topclef For This Useful Post:
    drugowaz (8th May, 2018)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Where to get new cards?
    topclef's Avatar
    Be advised , only the Renault clip can programme Laguna (2001-2005 ) with hand free , because this card has PCF7936 for start + PCF7952 for hand free .
    if all keys lost , the best way is the change the card reader and make card with 2 buttons
  6. The Following 3 Users Say Thank You to topclef For This Useful Post:
    drugowaz (8th May, 2018), RFRemotes (21st September, 2018), rokibar (13th November, 2018)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    So just swap reader and add new card as usual?
    No need program reader ?
    Or need change data in uch that car have no keyless?
  8. #6
    topclef's Avatar
    no coding to do , change reader and program card 2button, all will be fine , the only thing is the car owner will lost hand free option
  9. The Following User Says Thank You to topclef For This Useful Post:
  10. #7
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Ho problem . I think owners will agree if price will be good
  11. The Following User Says Thank You to drugowaz For This Useful Post:
    topclef (8th May, 2018)
  12. #8
    Jul 2013
    If the card is with autolock button you can program card with two.
  13. #9
    kostas's Avatar
    Jan 2009
    macedonia is greek
    Quote Originally Posted by Nikola1309 View Post
    yes you can
  14. #10
    Dec 2016
    Quote Originally Posted by topclef View Post
    blue connector ( not H F ) is the same of brown ?
    Not sure !
  15. #11
    topclef's Avatar
    Quote Originally Posted by TERMINATOR1000 View Post
    Not sure !
    not the same , but you can do a little modification, when we have the same situation ( all keys lost , card too expensive ) , the car's owner wants to start his car as soon as possible .
  16. #12
    drugowaz's Avatar
    Mar 2015
    Lithuania
    What mods need to be done?
    Repin wires or cut connector?
  17. #13
    Jul 2014
    Sofia
    Thanks for this info. What if we try to use card as original one and not changing reader? Should it work if we use an old card of same type and new properly precoded PCF7936 in it? What do you think guys?
  18. #14
    scotland clydebank
    so changing the card reader works on the laguna came across this a while ago and read on this forum that changing card reader works so what else is the modification are the connectors plug and play
    or need altered .
  19. #15
    HeXeN's Avatar
    Mar 2015
    What technically happen when I try to code 2button non-HF card (with hole) on a 3button reader (HF type, with sun button, without hole)?
