Results 1 to 10 of 10
    Portugal
    Default Ford radio conections
    Hi guys
    Does anyone got the wiring diagram for Radio AHU 8A6T-18C815 Ford Z series.
    Thanks in advance.
    rafal's Avatar
    UK - PL
    post picture of rear ( plug )
    need help
    now my goal is to buy xp-005
    who will help?
    Portugal
    For the moment I've just found permanent +12 V and Gnd. If you could tell me the other pinouts. I'll be grateful.
    Enviado do meu HTC One através do Tapatalk
    Portugal
    I've repaired the power of the radio, but when my client put the radio in car did not work at all.
    I think that the keyboard(that is OK) does not do nothing no power and etc..., when I put a CD it starts to read it but that's all it does. And I suspect that the LIN from keyboard is not activated by the radio and that pin I couldn't find it, or how this works.
    I'm attaching my findings about the pinout
    Help me to find the LIN on the radio or how this works.
    Thanks in advance
    Floridai, usa
    Quote Originally Posted by JotaB View Post
    Thanks in advance
    I'm not sure because the USA version has a different connector but it needs CAN bus to turn on/off and the front panel also works through the CAN, the display turns on? it should work even without the radio.
    Portugal
    Quote Originally Posted by djkrugger View Post
    Buy the datasheet of IC's in the keyboard panel there is no CAN IC just LIN BUS(I've tested it goes like this two ways IN/OUT one wire) to activate the panel from where does it come???? that is my problem.
    Do you have pinout?
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    Hi, i have same problem, radio dont switch on, but if i put the cd radio works but dont work painel
    anyone have fix this issues?
    regards
    Portugal
    Olá
    The problem is in the keyboard panel my friend. check my photo and test the keyboard panel. Check if it closes or open the doors e se funciona os piscas ;-) .
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    hi, yes, doors buton and 4 turn lights works on painel
    Portugal
    So the problem is in the keyboard panel. just substitute the panel (it's 50€ more or less)
