Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Oct 2017
    Quote Originally Posted by morgano View Post
    Nice. Glad it worked (in benefit of planet)
    of course
    Quote Originally Posted by Fec001 View Post
    Can you tell me what are the benefits when u use MAP smoke limiter instead of MAF on EDC15? Or is it only necessary when MAF reach measurement limit?
    I have just rebuilt a Golf mk4 PD130 and found the MAF is dead so thought I'd educate my self on MAF-MAP switching. Plus I think you could push the max IQ if necessary
  2. #17
    Feb 2013
    What is 1000 ?
    If it smokes you are allowing too much fuel to enter before there is enough air to burn it properly. The more you increase MAP based smoke limiter the more smoke you will get. Try lowering it. Or calculate it to 17 afr and it should not smoke.
    ((EngineCC/4) * (Boost/1000)) / 17
    That will give max value to each column in map based smoke limiter.
