Results 1 to 15 of 17
    May 2018
    mru
    Post eco sagem 2000 ver1
    Hello every body
    can someone help me on the ecu
    i want to set it as ori the immo have been removed due to a problem with remote control
    cheers
    fados13
    May 2018
    mru
    hello the car is a peugeot 406[2003] with ecu segem s 2000-1
    the ic in the icu is from [ST M28F512-12C3] IMMO have removed and cause the airconditioner to stop working
    what kinds of tools and software needed to return it back as ori
    fados
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    Quote Originally Posted by fados13 View Post
    fados
    Write back the original file using the programmer.
    May 2018
    mru
    hi raceshadow
    i think that when remove immo the file is not ori wright
    how can i read the M28F512-12C3
    what tool is needed
    fados13
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    May 2018
    mru
    hi OK i have a minipro programmer unit but in this case i want to read/virginised/write the ecu without removed the ic [i think it is a flash ] perhaps someone have used julie to remove the immo [what tool i need to read/virginised /write the ecu
    fados13
    May 2018
    mru
    fados13
    he where are you [still alive]???
    Did you mix up something? Sagem S2000-1 not using 28F512 !
    Oct 2016
    yes the s200-1 and all sagem s2000 for psa cars don't include tm28fxx !! just eprom 95080 , flash 29f200 !! you need to give us right informations so we could help you
    May 2018
    mru
    hi zmann/fady eid
    ok i will removed the ecuthe i will revert to all thanks a lot
    fados
    May 2018
    mru
    hi fady eid
    i confirm that the eprom is 95080
    how can i virginized and reprogarm it [what type of tool i need] thanks
    fad0s 13
    hi dear fados, you must have an original dump ; and you reactivate the vin and pin code .
    then activate the aircoditionner
  13. #13
    May 2018
    mru
    hi charifcharif
    where can i get the ori dump file
    fados13
  14. #14
    Oct 2016
    hi you need to read the eprom 95080 and post here so we will virgin it for you so ac will work again or try to immo off solution with working ac , for reading 95080 all programmers read this eproms easily ( upa usb , minipro , orange 5 , xprog )etc
  15. #15
    May 2018
    mru
    Hi fady eid can i used ecuvomix/immokiller to virginized the eprom ?
    fados 13
