hello the car is a peugeot 406[2003] with ecu segem s 2000-1
the ic in the icu is from [ST M28F512-12C3] IMMO have removed and cause the airconditioner to stop working
what kinds of tools and software needed to return it back as ori
fados
fados
hi raceshadow
i think that when remove immo the file is not ori wright
how can i read the M28F512-12C3
what tool is needed
fados13
hi OK i have a minipro programmer unit but in this case i want to read/virginised/write the ecu without removed the ic [i think it is a flash ] perhaps someone have used julie to remove the immo [what tool i need to read/virginised /write the ecu
fados13
Did you mix up something? Sagem S2000-1 not using 28F512 !
yes the s200-1 and all sagem s2000 for psa cars don't include tm28fxx !! just eprom 95080 , flash 29f200 !! you need to give us right informations so we could help you
hi zmann/fady eid
ok i will removed the ecuthe i will revert to all thanks a lot
fados
hi fady eid
i confirm that the eprom is 95080
how can i virginized and reprogarm it [what type of tool i need] thanks
fad0s 13
hi dear fados, you must have an original dump ; and you reactivate the vin and pin code .
then activate the aircoditionner
hi charifcharif
where can i get the ori dump file
fados13
hi you need to read the eprom 95080 and post here so we will virgin it for you so ac will work again or try to immo off solution with working ac , for reading 95080 all programmers read this eproms easily ( upa usb , minipro , orange 5 , xprog )etc
Hi fady eid can i used ecuvomix/immokiller to virginized the eprom ?
fados 13
