Here..................
Hi, I got this odo and only eeprom I see says 2904 and underneath 0006 , which doesn't look like correct one, here's the pic of the odo , any help would be appreciated.
D
GameTheoryOptimal (13th June, 2018), iboukane (12th July, 2018), specnaz (15th May, 2018)
Thanks Clusters, I totally missed it , print is barely visible on it , do I take it out to read with UPA or is there contact ports on the pcb I can solder my contacts to?
clear friend, the pin out can be achieved with a multimeter.
leave laziness
WINNER THE LOSER
Sorry , this is my second dash i'm working on, previously only successfully done it on Chrysler 300 with the MCU , I don't have much knowledge yet on how this is done or correctly measured, pins to the left of eeprom left on this particular board are going directly into the mcu , and other side seem to have maybe 3 available solderspots , data I found in UPA doesn't make too much sense to me...
Attachment 528416
here it is up close
OK , so I figured it out , I had it desoldered and soldered on extension board for UPA for that eeprom series.
Here is the dump for 93C76 x 16 , I have no idea what it's supposed to be since I got this odo from junkyard , can someone please set mileage to 172000 kilometers?
bump. anyone please?
Not with that dump, all FF FF
specnaz (17th November, 2018)
extension board?
if it is in a socket, make sure all your eeprom legs are clean, and that you have good contact. then try to read again.
if it is soldered on a board that plug into your upa, make sure you have good solder joint, and that chip is not backward or something.
good luck!!
yeah I desoldered it from the dashboard with hot air and soldered it with iron to my UPA extension board for that chip series , when I check voltage in UPA it says all OK and it says it read the chip, I just realized it was all FFs , hmm, is it possible I wiped the chip by overheating? I had trouble getting it off with hot air so it did get pretty hot...
back to the drawing board here , I checked orientation of the chip, problem with UPA board is that legs don't align perfectly for 93cXX with soldering points, so I just spent last 2 hours trying to soldering it on-off and usually gives wrong voltage , then i finally got it to read , but all memory addresses come as FF FF still. I ordered new board since I burned last one with hot air thinking I got it this time but.... Any idea if this could be read from some testing points on the board?
I can solder alright , that's not the problem, this eeprom is 3x4.5mm , clearances between pins are half millimeter , the soldering points on upa extension board are also microbial
