gibor (13th June, 2018)
Hello
good job , now you can program new keys with this software DDT4ALL :
https://mega.nz/#!mBsGTRpJ!9m3Gg4ikM...LasG50a_TEuSzI
Code PIN = code APV
1° "ENTER_AFTER_SALES" BUTTON
2° turn ignition on with all keys
3° "VALIDATE" BUTTON
B R
Sorry Terminator1000 you have big patience with me... Just for resume: connect elm and launch ddt4all turn on key select clioIII (clio 2010 is III version?) scan for ecu select ecu (you suggest BCM:X85 et J77 (PPP3 Vague1)) select after sales mode and put pincode to apv window push in after sales mode (my key is already on) after this push validate button, and the time of resync what is? (on panel of ddt4all view anything or not)? This part of procedure is for me obscure. Please clarify step by step (changing key 1-2..3, and eventual preliminar verify of key virginity) Thank you in advance!
Easy my friend !
1) copy / past PIN code
2) Enter in after sale mode ( 1 code is OK ) , "turn on" with all keys ( 1 to 4 )
3 ) Validate
gibor (15th June, 2018)
The brifing is ok. I'll let you know after receive the new elm327!
Hello, Im very happy Have received the interface.
Connected at pc and veichle. Tested the benchmark and the report confirm any relevant error
Clicked at connection mode > select my type of veicle > scan the ecu
select BCM and open after sales mode
put my pin and enter on after sales mode (1)
insert the first key and turn on the cdb > resync (1) turn off and put new key
turn on the cdb (two blink of light of immo) and resync (1) and light immo off
turn off the key and click validate.
All key and rf remote working well!!!
Thank you very match at TERMINATOR1000, and at this forum have permitted to resolved with bit money my struggle problem.
TERMINATOR1000 (17th July, 2018)
Hello. I used DDT4all to create a new keycard for megane 2. I used aftersales module from ddt4all to connect/create the new keycard, but this operation erased the 2 existing keycard from UCH. Solutions?
Its an Iron Cu..nt brada! The key programing begins allways with the deletion of the existing cards/keys. Usually you get a warning, that áll cards must be present, otherwise they Will be deleted...
this is an 5 minute process , an $5 cost
just watch this video : https://www.youtube.com/watch?v=IgF_lvr6T-I&t=80s
save the planet please destroy french cars !
This is the same tutorial i followed...and erased my 2 existing keycards from uch.
very happy , but you don't understand french ? ( all procedure was describe )
YOU NEED TO PRESENT ALL CARDS ( 3 in your case ! ) one by one in reader and push "card learning" when card present in reader ..... and finally push "validate" button !
In case of "hand free" cards TEST IT without battery to control them ....
AND an function read card present in reader exist to control cards Hand Free before start programmation , and soldering coils if is necessary !
https://www.youtube.com/watch?v=6dxBBJX1DIY
jon22jon (13th October, 2018)
If i do this now, with all 3 keys..... there is the risk of erasing the only key that works ?
Use a tool what you can understand, or get step-by-step instructions from T1000
