Results 1 to 4 of 4
    Default vw polo abs coding
    62 reg, 1.2. need help coding abs module. full scan of car attached. thanks
    Wednesday,16,May,2018,17:03:00:42542
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
    VCDS Version: 18.2.0.3
    Data version: 20180212 DS287.0
    www.Ross-Tech.com
    VIN: WVWZZZ6RZDU021862 License Plate: PJ62XSH
    Mileage: 47900km-29763mi Repair Order: KAL. 6R
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
    VIN: WVWZZZ6RZDU021862 Mileage: 47900km-29763miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine (J623-CGPB) Labels:. 03E-906-019-CGP.clb
    Part No SW: 03E 906 019 AK HW: 03E 906 019 B
    Component: SIMOS11.1 H03 7103
    Revision: --H03--- Serial number:
    Coding: 00110016000400080000
    Shop #: WSC 31414 790 50316
    ASAM Dataset: EV_ECM12MPI02103E906019AK 001006
    ROD: EV_ECM12MPI.rod
    VCID: 6DD11811BC37D02CC3-8038
    No fault code found.
    Readiness: 0000 0101
    Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
    Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 31414 790 31414
    VCID: 020B5BAD99A93F540E-8056
    4 Faults Found:
    03306 - Coding Not Valid
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 56
    Reset counter: 206
    Mileage: 47896 km
    Time Indication: 0
    Date: 2018.05.10
    Time: 07:50:16
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x3209
    Hex Value: 0x14AE
    Hex Value: 0x00FF
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 31
    Reset counter: 206
    Mileage: 47896 km
    Time Indication: 0
    Date: 2018.05.10
    Time: 07:50:16
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x3211
    Hex Value: 0x14AE
    Hex Value: 0x00FF
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 0
    Fault Frequency: 31
    Reset counter: 206
    Mileage: 47896 km
    Time Indication: 0
    Date: 2018.05.10
    Time: 07:50:16
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x3251
    Hex Value: 0x1BAE
    Hex Value: 0x00FF
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    00493 - ESP-Sensor Unit (G419)
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 31
    Reset counter: 206
    Mileage: 47896 km
    Time Indication: 0
    Date: 2018.05.10
    Time: 07:50:16
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x32E1
    Hex Value: 0x20AE
    Hex Value: 0x00FF
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
    Part No SW: 6R0 959 654 HW: 6R0 959 654
    Component: LENKW.SENSOR H07 0070
    Serial number: 18111713471000
    Coding: 01
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_LWSKLOVW25X 005001
    ROD: EV_LWSKLOVW25X.rod
    VCID: 7EF32F5DE1515BB46A-802A
    1 Fault Found:
    1140738 - Steering angle sensor
    B1168 54 [009] - Missing Calibration / Basic Setting
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 205
    Mileage: 47896 km
    Date: 2018.05.10
    Time: 08:00:28
    Voltage terminal 15: 11.30 V
    Voltage terminal 30: 11.50 V
    Terminal 15 status: On
    Address 08: Auto HVAC (J301) Labels: None
    Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
    Component: Man AC H02 0202
    Revision: 0003SH02
    VCID: 3979FC41B0FFBC8C1F-806C
    1 Fault Found:
    00898 - Control Circuit A/C compressor
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 25
    Reset counter: 246
    Mileage: 47800 km
    Time Indication: 0
    Date: 2018.04.18
    Time: 19:40:47
    Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 K HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0254
    Revision: BF046001 Serial number: 0434 227121361
    Coding: 24B02BBF08A10000003808002D2B0CD00040410F6006000020 0000000000
    VCID: 458180B1CC07C86C6B-8010
    Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
    Component: J386__TSG_FT 008 1611
    Serial number: KU0KU024081200013325
    Coding: 18BC30
    Subsystem 2 - Part No SW: 6R0 959 801 BB HW: 6R0 959 801 BB Labels: 6R0-959-801.CLB
    Component: J387__TSG_BT 003 8611
    Serial number: KU0KU020091300013658
    Coding: 0000A0
    Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H31 0033
    Serial number: 0228184
    Coding: 020000
    Subsystem 4 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
    Component: J388__TSG_HL 003 8610
    Serial number: KU0KU007101300010296
    Coding: 0000A0
    Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Serial number: KU0KU022081200011349
    Coding: 18BC32
    1 Fault Found:
    00907 - Intervention load Management
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 206
    Mileage: 47902 km
    Time Indication: 0
    Date: 2018.05.16
    Time: 06:53:26
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag027 H10 0020
    Revision: -------- Serial number: 003GX01CPEN+
    Coding: 003237
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250.rod
    VCID: 4A9BB38DED19271486-801E
    Crash sensor for side airbag: driver side:
    Serial number: 3575HRB405B1G7FSA145
    Crash sensor for side airbag: front passenger side:
    Serial number: 3585HRB401E59P4E89PM
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3515RRB40044UJ4SDPKF
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3525RRB405D1AP62H1UM
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 6R0 920 960 K HW: 6R0 920 960 K
    Component: KOMBI H04 0605
    Serial number: 00000000000000
    Coding: 440A01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
    VCID: 3D71E851ACD780AC33-8068
    1 Fault Found:
    10485825 - Internal Control Module Memory Check Sum Error
    B2000 41 [137] - General checksum failure
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H46 0254
    Revision: BF046001
    Coding: 002300
    VCID: 70EF0165A3053DC4E8-8024
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0605
    Serial number:
    Coding: 000000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6ADB130D8DD9C714A6-803E
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
    Component: SG EXT.PLAYER H18 0546
    Revision: A1001003 Serial number: 7663300879
    Coding: 010100
    VCID: 2A5BD30D4559071466-807E
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11250
    Shop #: WSC 31414
    VCID: 2F6DC219EABB623CB1-807A
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
    Component: Radio RCD310 004 0119
    Revision: 01000001 Serial number: VWZ1Z2M2184147
    Coding: 01000400020001
    VCID: 3561F0719CE758ECFB-8060
    End-------------------------(Elapsed Time: 02:37)--------------------------
    Jul 2016
    Vilnius
    try this one:
    230224E3216F00B3C42D24E884D300801300
    * MK100
    Jul 2018
    London
    hello,
    can any one help with bosch abs 8.2i long coding.i recently changed ecu kit on my polo match 2013 6r 3 door and put abs module in error mode not coded/adaptation along with esp and steering angle sensor.
    its 6R0907379BE
    HW:6r0907379AF
    esp8.2i front
    H050001
    imp648
    wsc00788
    vin:wvwzzz6rzcu0118
    started assembling the code myself but got lost in hex inverse
    any help is much appreciated
    i have vcds hex v2
    Jan 2017
    lettonia
    error in you vin:wvwzzz6rzcu0118 add number
