Results 1 to 4 of 4
    May 2018
    Australia
    Default Lexus LX470 2004 Cluster issue
    Gentlemen,
    I have a 2004 LX470 with instrument cluster issues. The dials work intermittently and "jerk" when start the car up first.
    I have had the cluster out to see what's going on but no found no obvious damage. Apparently it's a common issue with those and the only fix I found on other forums is the stepper motor replacement. Can anyone confirm that it'll fix the faulty gauges problem?
    I wanted to order a set of stepper motors and try replacing those, not sure where I can find them. I am attaching the pictures
    May 2018
    Australia
    Doesn't anyone have any idea about this issue?
    Feb 2016
    All the scales vibrate at the beginning only
    Is the data screen working properly
    When the solution is installed, the rotator rotates
    Hard to damage all
    Be sure to have 5 volts on the eeprom
    May 2018
    Australia
    Thanks for the message. All the needles vibrated at the start. Screen worked alright I don't think the eeprom was corrupted. The car is gone now but I remember the tacho needle and temp/fuel didn't work most of the time.
    Have you got a solution?
