I still need help
I still need help
not sure but....... try code 1234 with this dump.
i never change code so.......... ¯\_(ツ)_/¯..... also the dump has no calculated checksum
please report.
Edit: Remove Dump
ok.thanks,
my frıend eprom code data adress #4E0
checsum data #500 and #520
Sorry for that, try this.
I still do not know how to calculate the checksum.
try and report
Edit: Remove Dump
irfa (19th May, 2018)
mate I believe that without the checksum it will not work.
I really want to help you................. one last attempt ......... if it does not work try with your dump code 0123
Edit: Remove Dump
Checksum is not enough. Still very important 540h line. It's complicated
If you don't like it * close your eyes
--- Geros dienos ! ---
Thanks for helping my friend,but it does not work because there is no correct provisioning,again thanks
richiebb (19th May, 2018)
salam
I think the first two digits of the code is 55xx
"Stop racism, for we are all human beings"
irfa (20th May, 2018)
if this can help you in the attach there are files pair of nec and eprom95256
pre code from the label is B764
sorry frıends,I could not test the files because this radion screen was on the car,i will try it at the first opportunity when the car comes
Try ... 5678
nec renault bosch.rar
irfa (20th May, 2018), masterskay62 (20th May, 2018)
hello fellow IRFA.
I could decipher how is the checksum, 100% tested, as for the counter I'm not very sure, but analyzing several dumps I think I'm very close.
I know that you must be a little bit cranky to try ... let's do it one more time
I hope it works, this topic has taken my sleep.
regards
