hi
need pin code bcm
Brolk..
hi
need pin code bcm
Brolk..
Press "THANKS" button.
anjo008 (19th May, 2018)
BCM have eeprom? If I read this eeprom, how I could know pin code?
REgards
bcm have eeprom 93c66
post file
Brolk..
so it is possible to read eeprom from even the Opel Corsa C cluster and extract pin from that too?
Solved. Many thanks
how did you solve it?
Easiest way to get pins is read cluster in car with opcom. If modules are out of car read eeproms (or TMS from immo) and find pin. Either BECS encoded or in clear. All info here on DK. Corsa C are one of easiest to sort.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
