hello any help pls ??
hello friends
pls i need help i have a BMW X6 diesel 2009 model ecu Bosh the ecu was damaged by water i got another used ecu
attached the ecu isn readed by abritus with the cas i data abd the cas isn (16b)
pls can i get new cas data with ecu isn inside ?
Mate , please check u file that u post we cant open it
Imagination is more important than knowledge, because knowledge is limited ... while imagination creates the world.
hello pls i just check the file its a binary file it open normally
try 67 06 .........
how to change it in the cas data pls
with software BMW Isn
Hi, first of all you need to decrypt your CAS dump, only then you can change what you need...
not any other way!
cyril (21st May, 2018)
hello sorry can i get help about how to do that ?
Have you one working key and Hitag-programmer?
yes i have
ok read your key and post here screen of Hitag...
he already have encrypted ISN......
Just write CAS encrypted ISN in ECU and do sync, or post TV I will help you...
Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
can i write it witg abritus? i have all functions except egs unlock
