cas crypto need first decrypt post dump from ecu
BR EDDY
BR EDDY
dump crypto??
Hi, when the dump is crypted, ISN can only be seen when the ignition is on with the orig key, or you can read the engine control unit and check ISN from the dump
THANKS + REP if I help you
aslamaslam (19th May, 2018)
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
aslamaslam (19th May, 2018), richard27 (23rd May, 2018)
Reality of life :
3:Everyone lies
decryptet
BR EDDY
Why everybody posting isn from cas in all threads. With that isn car will not start. And all confirming this after test.
with explorer.
Key could be made by dump with this isn but car not starting
aslamaslam (20th May, 2018)
aslamaslam (20th May, 2018), droidwayne65 (20th May, 2018)
Reality of life :
3:Everyone lies
