Disconnect plug from pretensioner and join resistor 2,2ohm and clear errors and report ...
Best regards.
Dragon
Rtronics (22nd May, 2018)
HI, i have unplugged seatbelt and attached a 2.5 ohm resister and then a 2.1 ohm resistor. same error resistance too high see pictures.
Then i removed resistor and let it stay there with no resistor and not plugged in to seatbelt. still same error.
i have also attached picture of iprog software which is how i tried to clear crash dump. it says ok no errors.
any ideas what to do next. im thinking module problem.........
Failure is success, if we learn from it......Greetings from down under..... ( Australia )
Check on the bench, join resistor on the bench and check errors , sometimes problem with plug ...
Best regards.
Dragon
i dont know what you mean by check on the bench...…
i have cut the plug off the car and tested with resistor and without resistor. i still get same error resistance is too high.
now im 90% sure it has to be dump problem. unless you know something i dont.
Not all problem can be solved via edited dump, sometimes it is necessary to take in hands wiring diagram and the multimeter and all carefully to check up, if all wiring is ok - ACU must be replaced or repaired
Recently I had the srs unit from Hyundai i30 and in the plug was bug, when connect plug, 2 pins from pretensioner passenger's side was bridge. I spend some time for solve this :-)
Best regards.
Dragon
i tried another module with same original dump. im sure its dump problem. anyone have other tested dump i can try. and how to configure dump from other car to this one.
i have chinese odis but ive never tried it. i heard odis can install donor module. is this true
First do good backup ...
Best regards.
Dragon
