if it is nats5 post antenna sticker or bcm sticker to get pin
Hello friends, I need to program two new keys in Renault Scala 2012, I have work in this car with LAUNCH. Fistly I was tried to entry as Renault brand, but dont connection. In the second chance i tried as Nissan and the communication is well, even it shows me the VIN of the car. In anti theft it says uses NATS 5.0, this system is of NISSAN. When I connected with SBB I try with Nissan Almera Tino 2001-2004 and apparently I was connected, but the PIN is needed to program key, and I have not the PIN CODE. I was try to read PIN CODE by means of Option in SBB NISSAN BCM PIN CODE, but not connection. I have understand the BCM in this car is forming part of Dash board. I need to know how to get PIN CODE with VIN, and if I can to try with SBB even when for Almera Tino the key used is 4D, and Scala uses ID46. I have the two new keys in my hands, and i have another doubt, the news keys says when i readed with Zed Bull Mode Locked.
davidobd2 (21st May, 2018)
BCM in this car is in DASH. I need to review that.
Enviado desde mi E5306 mediante Tapatalk
It is a Sunny, not an Almera...
From other side it means that you can read the pin via OBD
I need to know if the code of six digits from BCM is in the case of this car in dash
I triee to read pun from BCM NISSAN in SBB but not work
Sbb is a bit overaged... Try a new one ;-)
For example. Please says me some tool not much expensive at least for this renault
Or for clone ID46
