Hello. Not my work but it is fantastic. Enjoy.
Hello. This ECU I have problem with ignition coil pack 1, no spark in spark plugs. I want to do immo off and put ecu on other car to eliminate the wiring problems. Car is far away and this is only solution. When I get the rubber out of the way I will post the pictures of the pcb. It is with 95080.
IF I HELPED YOU PRESS THE " T " BUTTON
Disconnect pin F3 plug2
Helder Costa (4th July, 2019), lfa450 (13th August, 2020), lion0304 (23rd July, 2021), PSAcars (23rd May, 2018)
