Results 1 to 7 of 7
    May 2018
    Default Help finding hysterisis maps in EDC16C34
    Hi, can anyone tell me where the 2 1x12 EGR hysterisis maps are in this file? I've searched and searched but just can't find them anywhere.
    Many thanks,
    K
    johak's Avatar
    1c5ebe 1c5f24
  3. The Following User Says Thank You to johak For This Useful Post:
    kevvo6969 (21st May, 2018)
    May 2018
    Wow! Quick work. I did think there were here but was following a guide and the numbers just didn't match up.
    I have created these 2 maps and set them to 0 hoping that the EGR will now be off. Will I still need to put a blanking plate in?
    Thank you so much - still don't know how you found them.
    K
    May 2018
    This was the picture I was working from - it looks nothing like the ones you pointed out..
    johak's Avatar
    better block it with a metal plate or disconnect plug, but you need to delete dtc related with egr
    May 2018
    Ah, I thought the above solution would mean no error codes. You know what my next question is then...... EGR DTC code location?
    Many thanks
    May 2018
    Update: ECU flashed and all appears well. No DTCs as yet but need to plug Lexia in to see what is actually going on.
