try again with more than 12V, ktag can accept 13.5V because I ever tried that
Dear Foremen of
I just bought KESS V2 V5.017 and Ktag K V7.020 Master Clone from a vendor recommended by a friend. Both are reformed by the seller to ensure proper operation. At all times the vendor has been very serious and the friend who recommended it to me assured me that it was trustworthy
When I got both interfaces, the vendor made his installation.
All very well up there, but when I try to read the first 2 control units (Magneti Marelli 4MV and 4BV) which I have urgency to read, in none of the cases was it possible to read
I put the details of the procedure below to see where you think the problem may be:
Procedure with Magneti Marelli 4MV Skoda fabia 1.4 Engine: BBY
Tool used Kess V2 using OBD2
This first reading was done in bank, proceeded with the pin-out correctly
The first error I receive is:
Warning, unknown ECU. For a correct procedure you must send log files and Reading to the technical support. Proceed anyway?
When giving OK, the program managed to read me the HW information
HW: MARELLI Boot 4MV r06
Upg. SW 036906034FD 4823
Then the next poster is:
Error while transferring data in Reading
Modify the speed of reading with each one of the variants that the Kess brings, but all in vain
Then connect directly the Kess to the OBD2 port of my car (Skoda fabia 1.4 BBY) that has an ECU equal to the aforementioned and the results were the same.
- When I tested on my car do not use external charger (The voltage was a little below 12V)
Do you think the solution is to increase and stabilize the voltage through an external charger?
Is the correct voltage just as important for a reading?
Procedure with Magneti Marelli 4BV VW Gol 1.0 Engine: AZN
Tool used KTag using Boot-Mode
In this particular case I decided first to check that the control unit worked properly, for this mount the ECU in the bank, with its correct pin-out but without connecting the gray cable boot mode, and proceeded with a reading of the ECU supporting me in the Vag-Com. Then the vag com could read the ecu, see fault codes, etc.
Already the possibility that the ECU did not work was ruled out.
Then I removed it from the OBD2 adapter and made the connection as the Ktag indicated, connecting the gray cable in its correct boot mode, etc. (I am sure that all the connections were made correctly)
When I give it to read, it gives me the following error:
Communication error with the ECU: control all connections; if the problem persists, send log file to the assistance
In this case as a power source use the original transformer that brings the ktag that also does not reach 12v.
Could this also be the cause?
I can connect directly to the Ktag in the power outlet that he brings, a 13-14V source, or it is advisable to connect directly from the external source to the control unit without going through the Ktag.
Can the ktag break if instead of using the original transformer that he brings, I connect an external source of 13-14V, 2Amp?
I have doubts too, it is correct that when the ktag with its original transformer connected if the voltage is measured in the red wires (+) is 0, but when I read it the ecu in the ksuite if it gives the 12V. Is this operation normal?
Given all these problems, contact the seller and he told me the following:
Magneti Marelli is the worst type of ECU are not reliable and can not always be read.
What do you think?
I see that both control units are on the kess list as the ktag, so they should be able to be read without any problem, I think.
Or are you in agreement with this and it is true that many times they give problem and can not be read even if they are on the list of ecu supported by alien-tech
The seller also told me to try other cars to see that everything was going to work properly, but to be honest I am afraid that trying to read a control unit of a car is going to block and stop stepping paper and more even being a beginner in this subject.
Is there a risk that the ECU can be blocked just by trying to read it?
Friends the truth that I have the head done a mess with all this and I do not know how to proceed in the future. I would like you to give me your opinions and comments to see what you think of all this. :desalentado::desalentado:
All help is welcome
Greetings to all
I was already able to read the Magneti Marelli 4BV ECU, with Kess V2 via OBD. I also read a Bosch Med 7.5.10 with the Ktag. I think the success was in maintaining a stable voltage with a regulated source.
I am very happy with the reading.
What do you say to me to read an ECU Simos 12.1 (Audi A4 1.8T 2014 Engine: CJEB) Is it possible?
I was reading that it is only possible with a virtual reading. As I understand it is not possible to read it, you can only access the ECU data, send it to the people of AlienTech and they prepare the reading from the data of the original ECU. Is that how I understood?
thanks for your help
Avega1984 (13th February, 2020)
8f3 , 5.017 obd2 Error while transferring data in Reading 4.036 perfect obd2
I have the same problem with a cm871 it says unknown ecu then i click continue anyway and after a long wait and cycling ignition many times as requested by kess it says wakeup error. I will try today with more voltage from truck batterie this truck has a vgt delete and i need that ecm image so much in the future. I have tried mb temic ddec 6 ecm with no problems.
