My customer played with it and he obviously totally killed.
Any info about the debricking? As far as i know the jtag port is open. Pinout dump..etc?
thx
thx
I try Jtag port programed AU13XX Ok but not work Maybe problem is Flash
He tried to downgrade it, as i know it's a simple nand.
do you have a pinout?
hola, podes subir imagenes del equipo cuando esta encendido, la pantalla que dice? imagenes de la pcb main...
RadioChiP (22nd May, 2018)
Hello, can you upload images of the computer when it is on, the screen that says? images of the pcb main ...
You can find pinout via Service manual Search google Service manual
Maybe need this?I have also dump of MX29LV320TT
But maybe have problem of Sandisk memory.
here I send a flash bin MX29LV320, I hope it serves you, in any case, the emmc memory could be replaced by a card SD.
link
https://wetransfer.com/downloads/43d...ecipient_email
jodge (23rd May, 2018)
Here another dump :https://files.fm/u/4f2htx7x#_
this is for LAN5200WR1
Question for user Neutec how to save file from emmc memory because is partition exFat and Fat16 and windows see only Fat32?
What program use to copy content of emmc card to sd card.I tried Usb image tool but this see only partition Fat32.
Thanks!
Hello, you can use the booticex86 application, select the partition, activate it and it will show active partition at that moment, so with all partitions, greetings.
https://wetransfer.com/downloads/07d...3114741/7e8c37
attilaa0 (23rd May, 2018)
i get the radio. Thx for the dumps
finally i understand this
there is two different storage in the radio:
-MX29LV320ET
-some kind emmc (doesn't matter the type)
the mx storing the basic opsystem like the PC bios
and the eemc stroing the maps..etc it's working like a hdd
If you stuck on the logo:
- Probably the emmc is dead. You can change to any type of emmc with the same package (BGA169). But before put in you have to create partitions, or you can change to a regular SD card BUT it's really slow stuff. Be careful with the removing bcose the eemc is glued to the pcb. (easy to losing some pins)
- Or maybe the rams are dead. It's made from really cheap low cost stuffs
Totally blank screen:
- Bad MX flash
- Bad update
you can fix the corrupt flash thru the jtag port or with a proper programmer (hot air, removing, tsop48 socket..etc)
In my case the owner didn't finish the update process and the MX is totally empty. Now my beeprog working on it
thx
Thanks!I wait for more details,after rewrite the Mx29lv.
with neutec dump not working at all. Probably bcose it's wr3 dump not wr1 (only 4 bytes diff)
with attilaa0 dump switched on but stuck on the dacia logo, after 3-4 sec on the screen appearing some withe dots blue shaking screen and dead. I think the emmc file system corrupted too.
i will working on the eemc soon
