Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    jodge's Avatar
    Mar 2017
    Default Renault / Dacia LAN5200WR1 Jtag
    My customer played with it and he obviously totally killed.
    Any info about the debricking? As far as i know the jtag port is open. Pinout dump..etc?
    thx
    Sir, are you classified as human? Negative, I am a meat popsicle
    Jan 2012
    Europe
    I try Jtag port programed AU13XX Ok but not work Maybe problem is Flash
    jodge's Avatar
    Mar 2017
    He tried to downgrade it, as i know it's a simple nand.
    do you have a pinout?
    Mar 2016
    Argentina
    hola, podes subir imagenes del equipo cuando esta encendido, la pantalla que dice? imagenes de la pcb main...
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by neutec View Post
    Use ENGLISH only here..
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  6. The Following User Says Thank You to shooting For This Useful Post:
    RadioChiP (22nd May, 2018)
  7. #6
    Mar 2016
    Argentina
    Hello, can you upload images of the computer when it is on, the screen that says? images of the pcb main ...
  8. #7
    jodge's Avatar
    Mar 2017
    Only white screen. No text, no logo, nothing.
    About the pcb picture...'ll get it tomorrow the radio bcose i just got the job right now
    btw here is the pinout:
    1,2,6,9 = GND
    10 = TCK
    11 = TMS
    12 = TDO
    13 = TDI
    14 = TRST
    16,17 = 3.3V
  9. #8
    Jan 2012
    Europe
    You can find pinout via Service manual Search google Service manual
  10. #9
    Sep 2009
    Romania
    Maybe need this?I have also dump of MX29LV320TT
    But maybe have problem of Sandisk memory.
  11. The Following 4 Users Say Thank You to attilaa0 For This Useful Post:
    aliahmadi (22nd January, 2023), irfa (22nd May, 2018), jodge (22nd May, 2018)
  12. #10
    Mar 2016
    Argentina
    here I send a flash bin MX29LV320, I hope it serves you, in any case, the emmc memory could be replaced by a card SD.
    link
    https://wetransfer.com/downloads/43d...ecipient_email
  13. The Following User Says Thank You to neutec For This Useful Post:
    jodge (23rd May, 2018)
  14. #11
    Sep 2009
    Romania
    Here another dump :https://files.fm/u/4f2htx7x#_
    this is for LAN5200WR1
    Question for user Neutec how to save file from emmc memory because is partition exFat and Fat16 and windows see only Fat32?
    What program use to copy content of emmc card to sd card.I tried Usb image tool but this see only partition Fat32.
    Thanks!
  15. #12
    Mar 2016
    Argentina
    Hello, you can use the booticex86 application, select the partition, activate it and it will show active partition at that moment, so with all partitions, greetings.
    https://wetransfer.com/downloads/07d...3114741/7e8c37
  16. The Following User Says Thank You to neutec For This Useful Post:
    attilaa0 (23rd May, 2018)
  17. #13
    jodge's Avatar
    Mar 2017
    i get the radio. Thx for the dumps
    finally i understand this
    there is two different storage in the radio:
    -MX29LV320ET
    -some kind emmc (doesn't matter the type)
    the mx storing the basic opsystem like the PC bios
    and the eemc stroing the maps..etc it's working like a hdd
    If you stuck on the logo:
    - Probably the emmc is dead. You can change to any type of emmc with the same package (BGA169). But before put in you have to create partitions, or you can change to a regular SD card BUT it's really slow stuff. Be careful with the removing bcose the eemc is glued to the pcb. (easy to losing some pins)
    - Or maybe the rams are dead. It's made from really cheap low cost stuffs
    Totally blank screen:
    - Bad MX flash
    - Bad update
    you can fix the corrupt flash thru the jtag port or with a proper programmer (hot air, removing, tsop48 socket..etc)
    In my case the owner didn't finish the update process and the MX is totally empty. Now my beeprog working on it
    thx
  18. The Following 3 Users Say Thank You to jodge For This Useful Post:
    attilaa0 (24th May, 2018), ilen (24th May, 2018), RadioChiP (24th May, 2018)
  19. #14
    Sep 2009
    Romania
    Thanks!I wait for more details,after rewrite the Mx29lv.
  20. #15
    jodge's Avatar
    Mar 2017
    with neutec dump not working at all. Probably bcose it's wr3 dump not wr1 (only 4 bytes diff)
    with attilaa0 dump switched on but stuck on the dacia logo, after 3-4 sec on the screen appearing some withe dots blue shaking screen and dead. I think the emmc file system corrupted too.
    i will working on the eemc soon
