Results 1 to 8 of 8
    werner5395's Avatar
    May 2008
    Tabor CZ
    Default Jeep cherokee 4.7 1996 PCM exchange Please Help
    Hello
    orginal PCM defekt - custom order a used one now i must change it- i only have for this car Launch Tester- he has function PCM change but would like to have code- I do not know where I get this- Can someone help me and tell me how to write the vinnumber into this PCM - thank you very much-
    sorry for my bad English
    Ahmy501's Avatar
    Jun 2016
    You only need to change the vin number in the new PCM any tool can easily get this job done if you have abrites commander, Maxidas, DRB etc.
    Good luck
  3. The Following User Says Thank You to Ahmy501 For This Useful Post:
    werner5395 (26th May, 2018)
    Ahmy501's Avatar
    Jun 2016
    the 4.7 engine was only released in 1999 onward SUVs are u sure your Jeep is MY1996
  5. The Following User Says Thank You to Ahmy501 For This Useful Post:
  6. #4
    keymax's Avatar
    Quote Originally Posted by werner5395 View Post
    Hello
    If it’s a 1996 then no programming needed to start and run the car but the 4.7 is only in the 1999 and will be immobilized. You can program through skim functions (PCM replace) with DRB3, Dart, Maximus,etc...
  7. The Following User Says Thank You to keymax For This Useful Post:
  8. #5
    werner5395's Avatar
    May 2008
    Tabor CZ
    it is 10/2000 Ahmy501 and keymax you are right- my mistake
  9. #6
    droidwayne65's Avatar
    Aug 2015
    North America
    With your Launch: ECM > Miscellaneous > Check VIN. Write the original VIN and you're done.
  10. The Following User Says Thank You to droidwayne65 For This Useful Post:
  11. #7
    werner5395's Avatar
    May 2008
    Tabor CZ
    Thanks to all- Launch do it but need Brain- Thanks droidwayne65
  12. #8
    Aug 2015
    North America
    You're welcome.
