Results 1 to 15 of 22
    sasy90's Avatar
    Italy
    Default Iveco Daily 2013 BCM change km
    Hi ,
    i've a Iveco Daily of 2013 year with 95640 TSSOP in BCM.
    Ori km are around 360000km
    I need 81000km.
    I need tested solution because i don't have EASY IVECO to test.
    Thanks in advance
    Mar 2016
    Argentina
    hello
    your file is already on 83xxx
    you have to change in dash
    sasy90's Avatar
    Italy
    Impossible m8... i read the print of IVECO EASY one mounth ago and i've seen 361000 around.... in dash already mod and all ok but only in diag IVECO see old km and i want change it...
    bulanbulanov's Avatar
    Italy, Abruzzo, Teramo
    Default Try this file !
    Quote Originally Posted by sasy90 View Post
    Hi ,
    I need 81000km.
    Thanks in advance
    Please report !!!
  5. The Following User Says Thank You to bulanbulanov For This Useful Post:
    sasy90 (22nd May, 2018)
    sasy90's Avatar
    Italy
    Thanks m8... but i can't report if works or not...
    sasy90's Avatar
    Italy
    nobody has tested version done with dp4?
    sasy90's Avatar
    Italy
    Nobody can help me?
    This is better than DP4 !!!!!
    Come on, don't be picky( Dai compa', non fare lo schizzinoso !)
  10. The Following User Says Thank You to bulanbulanov For This Useful Post:
    sasy90 (23rd May, 2018)
  11. #9
    sasy90's Avatar
    Italy
    hi, m8 your file works 100%...
    Can you do another file?
  12. #10
    put it here !
  13. #11
    sasy90's Avatar
    Italy
    Hi m8 ,
    i've another iveco Daily ...can you help me?
    ORI in dash : 235447km
    NEW: 91000km
    Thanks in advance
  14. #12
    here is your file
  15. The Following User Says Thank You to nikz For This Useful Post:
    sasy90 (21st June, 2018)
  16. #13
    Default try this !
    Hi m8 ,
    NEW: 91000km
    Thanks in advance
    Please report !
  17. The Following User Says Thank You to bulanbulanov For This Useful Post:
  18. #14
    Quote Originally Posted by nikz View Post
    here is your file
    Two positions you forgot:
    h0EDE => 199629Km
    and
    h0EE2 => 201785 Km
  19. The Following User Says Thank You to bulanbulanov For This Useful Post:
    clauberty (23rd January, 2019)
  20. #15
    sasy90's Avatar
    Italy
    Thanks m8 bulanbulanov!!! you're the best!!!
