yep, first help other than we think about your tune
FILE SERVICE
not for free mate, !!
im eletronik freak i can help many people but im new here, this is for my own car.
a nice day to you
this is your car?
FILE SERVICE
yes its my own car
File for You MOD.
rares01 (23rd May, 2018)
your file, 400nm and 180ps. If you like disconnect all sensor from dpf.
FILE SERVICE
AVDigitale (24th May, 2018)
hi , can someone help me with tunning this ori file?
Rares01 wrote so! Not need DPF off.
yeap but he write " I edit dpf off and egr " , in my file have emulated all sensor from dpf and never emergency mode when they destroy.......
FILE SERVICE
Voltechcar is right.dpf and egr off needed to. Ty to all today i will reply and tell you what happends
i have write voltechcars dump, i see changes, a litle bit more power but i think when i take the dpf ceramik out i will see more.for those who have problem with the cruisecontroll after reflash, i have found the solution , i had the same problem on my car after dpf egr off
tryed many things with clip and others and nothing hapends.
first thing you must do is to put your tempomat button on limiting mode, now try to read the ecu again .
after reading compelte all shoult be came to normal because the car is learning agains this function .
and be carefully in future read and write the ecu with the cruse controll buton pushed.
this is normal..... after writing you must always switch on off cruise than he works always.
FILE SERVICE
thanks both of you i decide to use voltechcar s map. ty
i have tested both of them
