Results 1 to 9 of 9
    khaled dar's Avatar
    May 2017
    From Syria I live in Saudi Arabia
    Default 20777732 denali 2009
    Hello my friends I need to clean this file
    denali 2009
    p/n : 20777732
    eeprom: 95160
    USA
    i compered to my files-looks like bad read
    but here is clear pass pm
  3. The Following User Says Thank You to alexs600 For This Useful Post:
    khaled dar (24th May, 2018)
    khaled dar's Avatar
    May 2017
    Thank you my friend but the file you sent me does not open
    khaled dar's Avatar
    May 2017
    No one has a clean file, my brothers ??????
    USA
    working on my end
    did you get pass
    khaled dar's Avatar
    May 2017
    The file does not ask for a corrupted file password that never opens my friend
    epd1221's Avatar
    Nov 2011
    usa
    dont they clear obd2 with any good scanner if all in vehicle is fixed , i just finish a 2010 replace seat belts clear codes and all good
    Plcautoparts's Avatar
    Mar 2013
    2010 Its a totally different module, yours is the plastic black box, the requested one is aluminum with brown silicon at the bottom!!
    A simple thanks would do, If it didn't work at least I tried.
  10. #9
    Mar 2013
    Your data doesnt look right, could you read it one more time, make sure the clip or what ever are using maskes a good contact with eeprom, also compare once read to make sure your data was well read. and then I will clear it for you!!!!
