Ford Fiesta 58 Plate help
Results 1 to 7 of 7
    Sep 2011
    Default Ford Fiesta 58 Plate help
    Ive got a 58 plate fiesta zetec 1.4 it has started to give me problems this week. Every morning when i go to work i start the engine it starts first time the rev counter goes up then the revs drop to about 700 rpm then the engine cuts out. This also happens when i leave work so its a cold start problem. If i keep the revs up for a minute from cold start it starts to run fine and the revs at idle level out between 900/1000 rmp. I have searched online for answers and have only come up with its either the idle control valve (which i cant confirm as to weather or not this model actually has), or split breather hose or to clear the KAM memory. I have had the elm device plugged in and no faults were shown. I just wondered if anyone had any thoughts before I go pulling parts off at the weekend. Thanks
    edit: also would a professional diagnostic device show any errors as apposed to an elm with forscan etc
    Jul 2013
    yorkshire
    More expensive gear might show you more in regards to live data. If you have the mil on the code is set, so your elm will read it. Have you done a visual check of the pcv pipes? These are very common.
    Sep 2011
    Not as yet just wanted some advice before I go taking it apart. What do you mean by - If you have the mil on the code is set, thanks
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    Quote Originally Posted by madhatter View Post
    Den means if the engine management light is on theee is a fault code stored and your reader would be able to read it
    PS3= krazylegz120282
    Sep 2011
    Oh no there is no engine management light on it only passed it’s not last week only fault it had was a blown bulb. This problem just seems to have came from nowhere. Gonna try have a look at it tomorrow check pcv pipes etc as suggested
    Jul 2013
    yorkshire
    You dont need to strip it or remove anything to check pcv pipes, just a good light. Oh and Forscan is one of the better scan tools, i use it all the time.
    Check the battery m8. Seen this problem a few times.
