Try this one
Try this one
Dejfat (25th May, 2018)
this one was also corrupt by fvdi
When you use the
THANKS and REP Buttons
it gives energy to help more
Appreciation is the key
PROBLEM SOLVED THANKS
When you use the
Hi dejfat
Can you please share your solution or assist. I have 1.2 blue motion tdi also instrument dead. I use petrol dump to correct it but rev counter and speedo does not work. After new dump check sum error dissapeared. I am stuck now. Can you assist please.
I am repairing after someone made keys and left customer like this. Thanks in advance
What cluster do you have.do you have the dump from the car?.
In my case I was doing the mileage with fvdi and It went blank and car could not start. Send me your dumped I can try to compare and correct. You maybe lucky
When you use the
ascotauto (25th May, 2018)
Tx for the reply
Attached is dump. Apparently someone made keys for my one. My car starts fan was running with. Now no fan but gauges not working. tacho and speedo.
is your dash number 6r0920861H. your dump look very much damaged but i will try. does it show mileage?
When you use the
Shows nothing dead dead dead
try this. i am not sure of the immo data. you may have eep09 on dash
When you use the
file shows damaged an i cant exrtract
here is the zip format
When you use the
No go boss car doesnt start cluster dead not coming on. Last dump i posted car was starting
Ok . Will prepare another dump
is your eeprom 95320
When you use the
