Hello ,I have this cluster Instruments Labels: 1K0-920-xxx-17.lbl Part No: 1K0 920 862 J
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023103
Shop #: WSC 00011 888 96745
VCID: 31689860A8FDBECE35-8064
and this Immobilizer Labels: 1K0-920-xxx-25.clb Part No: 1K0 920 862 J
Component: IMMO 3HL 4312
Shop #: WSC 00000 000 00000
VCID: 31689860A8FDBECE35-8064,
And I want with this cluster
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 874 A HW: 1K0 920 874 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0GD3N495A
Coding: 0007103
Shop #: WSC 40970 222 21387
VCID: 2B548A088AD1D41E0F-807E
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1216
Shop #: WSC 00014 204 81388
Thanks and have a good night !
Full immo data can only be read by OBD, not by eeprom alone!
(It is encrypted inside)
I have scan with vcds hex
Monday,05,February,2018,08:51:21:54500
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ1KZ6M745038 License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 69 72 76
VIN: WVWZZZ1KZ6M745038 Mileage: 134430km-83530miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03C-906-056-BAG.lbl
Part No SW: 03C 906 056 DP HW: Hardware No
Component: MED9.5.10 G00 9970
Revision: --H01--- Serial number: VWZ7Z0E3179095
Coding: 0000072
Shop #: WSC 73423 133 180419
VCID: 74E65174176FCBE69E-8020
No fault code found.
Readiness: 1110 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0002689
Shop #: WSC 00066 000 00000
VCID: 71E85860687DFECE75-8024
1 Fault Found:
01309 - Power Steering Control Module (J500)
008 - Implausible Signal
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BE
Component: ClimatronicPQ35 090 0808
VCID: 6BD44A084A51141E4F-803E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000230099
Coding: 01078E2700041800000A00000F00000000095D035C
Shop #: WSC 00066 123 12345
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 00066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: 2J AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD02KX9O
Coding: 0012874
VCID: 3B74BA487AB1449E9F-806E
Subsystem 1 - Serial number: 6332MSME0C5C717ET
Subsystem 2 - Serial number: 6342MSME0C71317CF
Subsystem 3 - Serial number: 6351HSME30166348+
Subsystem 4 - Serial number: 6361HSME086F6651F
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 634 0070
Coding: 0000041
VCID: 76E26B7C0113D9F6A0-8022
Coding: 0023103
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 26031400F16287
Coding: 351002
Shop #: WSC 12345 123 12345
VCID: 76E26B7CC113D9F6A0-8022
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 M HW: 3C8 035 279 M
Component: RNS315-EU H70 0407
Serial number: VWZAZ2N0379229
Coding: 000004110400000000000001
Shop #: WSC 41228 123 104857
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3560AC70949592EE69-8060
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V4 0050
2 Faults Found:
1048599 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 134438 km
Date: 2000.00.00
Time: 08:50:05
1048600 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 134438 km
Date: 2000.00.00
Time: 08:50:05
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0000244
VCID: 3662AB7C419399F660-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326A976CADFB85D64C-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00D802087F2D8607484F01E011A0
Shop #: WSC 73423 133 21157
VCID: 79F86040300DB68ECD-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000244
VCID: 377CA678469960FE7B-8062
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 3364926852E18CDE47-8066
Address 69: Trailer Labels: 8P0-907-383.clb
Part No SW: 8P0 907 383 HW: 8P0 907 383
Component: ANHAENGERELEKTR H01 0010
Coding: 0000001
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 3466917457EF8BE65E-8060
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 35 Einparkhilfe 0101
VCID: 2D508410B4C5DA2E11-8078
End-------------------------(Elapsed Time: 02:20)--------------------------
