Results 1 to 2 of 2
    marek128's Avatar
    Jun 2012
    Default VW Polo 2009 ABS CODING fault - know algo
    Hi.
    Hawe Polo 2009 with fitted used ABS PUMP:
    OLD\DAMAGED 6R0907379 AB
    USED\WORKING 6R0907379 S
    Working coding from old one:
    200200E3007200B2042900EB00D600000000
    Used actualy fited:
    000000000000000000000000000000000000
    This codind dont match to new fitted pump.
    With new pump hawe faults:
    03190 - incorrect vechicle
    01042 - not coded
    VIN: WVWZZZ6RZAY050495
    I tried to calc coding from thi:
    We can use this information, together with my description, to determine the correct coding for our own Polo 1.6 TDI.
    Byte 0:
    HEX - Chassis type
    10 - Ibiza Hatch and ST
    20 - Polo hatchback
    As you can see, there might be some options for Fabia hatch and station,  Audi A1, etc. Therefore it's always good to google scans of similar  cars to your own.
    Byte 1:
    HEX - Chassis type
    02 - Polo and Ibiza
    Byte 2:
    HEX - Brake diameter
    24 - Front 256mm disc - rear 200mm drums
    28 - Front 256mm disc - rear 230mm disc
    44 - Front 288mm disc - rear 200mm drums
    48 - Front 288mm disc - rear 230mm disc
    Byte 3:
    HEX - Chassis type
    DB - Ibiza
    E3 - Polo
    Byte 4:
    HEX - Transmission type
    01 - Manual
    Byte 5:
    HEX 6D + VIN digit #13
    Byte 6:
    HEX 00
    Byte 7:
    HEX B2 + VIN digit #14
    Byte 8:
    HEX - Chassis type
    08 - Ibiza Hatch and ST
    04 - Polo hatchback
    Byte 9:
    HEX 25 + VIN digit + 15
    Byte 10:
    Inverse of byte 2
    You'll convert the HEX value to binary, i.e. HEX 21 = BIN 00100001. Then  you invert the binary value, so 00100001 becomes 10000100. Finally you  convert 10000100 to HEX, making 84.
    Byte 11:
    HEX E2 + VIN digit # 16
    Byte 12:
    Inverse of byte 4 (see byte 10)
    Byte 13:
    HEX D1 + VIN digit # 17
    Byte 14:
    Inverse of byte 6 (see byte 8 for description)
    Byte 15:
    bit 1: TDI engine installed
    Byte 16:
    bit 1 = TPMS active
    Byte 17:
    HEX 00
    This calc its match to old coding (VIN)
    But fitted abs says coding wrong same when i change something in old and try to code - only original coding accept.
    If I help You. please say THANKS.
    Jun 2016
    which tool your using for coding?
    We make A
    Living by
    What we get,
    but we make a
    life
    by
    What we give.
    -Winston Churchill
