Results 1 to 12 of 12
    Jul 2016
    USA
    Default 2006 Passat odometer mileage correction
    2006 Passat , need to do odometer mileage correction.
    only needs mileage to be changed in cluster ?
    and what eeprom 24c32 ?
    Cllau's Avatar
    Mar 2017
    where friends need me
    OBD ........
    Jul 2016
    USA
    Quote Originally Posted by Cllau View Post
    OBD ........
    customer brought me cluster out of the car
    Jul 2016
    USA
    if cluster is out of the car ?
    Can the mileage be corrected just on the eeprom chip in the cluster ? Or also needs to be done in immo and ecu ?
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by borshch View Post
    I think it's also possible, you just have to locate the lines of 12+ and GND and Ch / Cl, as the case may be.
  6. The Following User Says Thank You to Dr. Zoidberg For This Useful Post:
    borshch (27th May, 2018)
    Jul 2016
    USA
    is there eeprom I can reprogram ?
    I have eeprom programmer but for obd tool I only have launch x431
    No, impossible by eeprom only. OBD job
    levisdj's Avatar
    EcuLand
    It should be a 24c32 inside ...must disasemble whole dash
  10. The Following User Says Thank You to levisdj For This Useful Post:
  11. #9
    Yes, 24C32 inside but km is stored encrypted. Impossible to change mileage without knowing key from Micronas. oBD job or Xprog-m by reading key from Micronas. Don't waste your time looking for none existing solutions...
  12. The Following User Says Thank You to exe123 For This Useful Post:
  13. #10
    Jul 2016
    USA
    thank you guys for answers. Wow didn't know that eeprom can be encrypted!
  14. #11
    Cllau's Avatar
    Mar 2017
    now you know...
  15. #12
    SxL'.xll's Avatar
    Oct 2017
    Flux island
    obd using abrites
  16. The Following User Says Thank You to SxL'.xll For This Useful Post:
    borshch (29th May, 2018)
