Results 1 to 3 of 3
    GB
    Default FORD MUSTANG 2005 4L 5R3A-12A650-ADD PCM170F VK2-R3514
    Hallo
    I have problems with FORD MUSTANG 2005 4L
    car after discharge battery ECU and IC lose all data and car do not start .
    I try add new keys ( PATS programming ) but witout any sucess .
    Need eeprom dump with ECU 5R3A-12A650-ADD PCM170F or any similar .
    Does anyone know Tacho <-> ECU or BCM <-> ECU are Immobiliser pairing ??
    in BCM are Infineon 21002558 and SPI EEPROM Microchip 9365217
    in Tacho are Motorola HC912 3L40K
    Thanks anybody for help!
    GB
    Hallo a
    I try many Times add keys by diagnostic tool and other key tool but unsucess ;(
    in the ECU spi memory 95040 can anybody help check and correct the EEPROM and pair with the key
    Read Key
    DATA 03 00 FAF72001
    RESP: BEA182 228FC7
    INFOST **L*
    TYPE:4D 63 CRYPTO WR
    GB
    Solved - car now working well ! problem in coil - now can add key with diagnostic tool .
    Greetings .
