Results 1 to 13 of 13
    koziolek's Avatar
    Under the car
    Default 2001 Audi TT instrument cluster swap
    Need to swap instrument cluster on 2001 TT
    can someone guide me with procedure please
    Already tried to read pin from new(used) cluster using FVDI did not work
    tried with OBDSATAR100 pro no success
    there is no original cluster customer saying that is damage completely.
    3inferno3's Avatar
    Nov 2014
    Europe
    MM73 OR VDO?
    ascrap2003's Avatar
    Sep 2016
    Texas
    I think VCDS VAG is needed
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
    ascrap2003's Avatar
    Sep 2016
    Texas
    Quote Originally Posted by koziolek View Post
    Invest in tools!
    koziolek's Avatar
    Under the car
    Thats what i read from new(used) cluster
    for some reason owner said that he does not have original one
    in this replacement one i see sighn that someone was already played with it.
    Pin from ECM is :3563
    Can someone retrieve pin from attached file
    and can mileage be change to 170200?
    rafal's Avatar
    UK - PL
    pin 01318...........
    need help
    now my goal is to buy xp-005
    who will help?
  7. The Following User Says Thank You to rafal For This Useful Post:
    koziolek (26th May, 2018)
    koziolek's Avatar
    Under the car
    pin not accepted
    see attachment
    mileage OK
    rafal's Avatar
    UK - PL
    pin not accepted
    see attachment
    mileage OK
    old mileage 278940?
    check value in measurement block 024
    need help
    who will help?
  10. The Following User Says Thank You to rafal For This Useful Post:
  11. #9
    koziolek's Avatar
    Under the car
    mileage 278940 was orig, after you change 170 002 its fine .
    i will check
    value in measurement block 024 on Monday
  12. #10
    koziolek's Avatar
    Under the car
    Back to this car again ,
    the bad thing is that car is not in my shop
    people just delivered instrument cluster to my shop
    than they play on their own.
    today they sent scan from that audi
    i see error in ecm
    1 Fault Found:
    18058 - Powertrain Data Bus
    P1650 - 35-00 - Missing Message from Instrument Cluster
    and in kombi there is no vin and immo ID
    but ECM shows that .
    Is this mean that cluster its not for this car is it older?
  13. #11
    koziolek's Avatar
    Under the car
    Somehow he found original cluster ond of course has immo id and vin in it when checked by vcds
    i found that original cluster has fuel gauge problem
    arrow goes opposite way
    i switched motor from scrap cluster did not solve the problem still the same
    when i put motor from original to scrap all is fine so it looks like motor its not the problem
    does someone have such a thing before ?
  14. #12
    rafal's Avatar
    UK - PL
    pull fuse 15 & 28, turn ignition or try to start the car (wont start because no fuel pump...), then put fuses back
    need help
    who will help?
  15. #13
    Oct 2015
    Hello. The reverse fuel gauge is not a hardware problem. Pre 2001 cars and post 2001 cars have different linearisation in cluster software. One is 55ohm low fuel and 255 max fuel and the other 255 low fuel and 55 max fuel. You can solve this by moving the HC08 and HC12 dumps from the old cluster to the new one. This will move km and immo as well. Keep the original dumps safe in case anything goes wrong.
  16. The Following User Says Thank You to spitt For This Useful Post:
    GameTheoryOptimal (3rd June, 2018)
