Results 1 to 15 of 20
    HeXeN's Avatar
    Mar 2015
    Default VW Passat B8 2015 keyless key programming
    Any chance to program new key except dealer?
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by HeXeN View Post
    Very good qustion, that’s the next thing I have to do lots off reading as I was told the new chip is ID46 so you may able to copy then programme remote..
    HeXeN's Avatar
    Mar 2015
    I found info there is two types of keys ID48 CAN & Megamos 88
    topclef's Avatar
    AVDI Can do it , except JCI dash and Virtual coockpit
    transponder : Megamos-extended AES
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  5. The Following User Says Thank You to topclef For This Useful Post:
    HeXeN (27th May, 2018)
    Feb 2014
    I've heard AVDI hangs sometimes in the middle of the procedure - making the car completely dead after this.
    How about North America Passat end of 2016? It has non-keyless key. It doesn't look like MQB ID88. What tool can do it and what transponder to use?
    topclef's Avatar
    Quote Originally Posted by autoTkey View Post
    now the software is stable follow only the procedure , no problem .
    all Passat B8 2015+ in the world is MQB-Platform , there is with Keyless and with regular key .
  8. The Following 2 Users Say Thank You to topclef For This Useful Post:
    autoTkey (5th June, 2018), PocketHero (5th June, 2018)
  9. #7
    Feb 2014
    You were wrong friend - some cars above 2015 and mostly all above 2017 have a newer system which is not MQB and can't be done. Only dealer can help. OBD tools recognise it falsely and can give you a lot of headeich, so be careful! If the key reading tools like VVDI Key tool don't recognise the working key as ID88 then it's not MQB.
  10. The Following 3 Users Say Thank You to autoTkey For This Useful Post:
    PocketHero (21st September, 2018), rokibar (14th September, 2021), yugo45 (22nd September, 2018)
  11. #8
    Jun 2011
    I did a mqb Passat the other week with vvdi2, did give a few warnings saying if fails on programming need online dealer tool and also don’t switch the ignition off while programming
    everything went well for me and added the new key
  12. The Following 4 Users Say Thank You to zippy82 For This Useful Post:
    amigokola (22nd September, 2018), immoneard (26th May, 2020), Jobeso66 (23rd September, 2018), Rakija (26th December, 2020)
  13. #9
    May 2018
    types de clés ID48 CAN & Megamos 88 MAGIC3
  14. #10
    Sep 2016
    Its nearly impossible that B8 will use id48. Probably wrong info on autokeys sites.
  15. #11
    Apr 2017
    No problem with abrites and VVDI i test it it works very good.
    Only VDO cluster key its 88-AES
    Best regards
    Moes
    Verzonden vanaf mijn iPhone met Tapatalk
  16. The Following User Says Thank You to mustafabahar For This Useful Post:
    p1et (28th April, 2019)
  17. #12
    Oktawian's Avatar
    Sep 2016
    Any new info on passat b8 all key lost ?
    Only dealer or is there 2nd option ?
  18. #13
    Nov 2020
    Hi guys I am owner of Passat B8 2.0 tdi BMT 2015. and I also have Golf MKIV sdi from 2002.
    We have a lot of info and an excellent thread how to retrieve lost and code new keys for old cars here https://www.digital-kaos.co.uk/forum...-or-true/page8
    But we don't have any useful info for new cars...
    It is frustrating to take car to dealer in order to make a new key...
    You guys mentioned Abrites and VVDI?
    ​What is this and where could we download them. Thanks...
  19. #14
    for akl is were and option to get data with vvdi2 by obd.
  20. #15
    Feb 2014
    Quote Originally Posted by Rakija View Post
    You are right! It is frustrating specially for your wallet. So you better go to the local locksmith. If you are just an owner of a car and making keys is not what you work, then better not bother with VVDI and AVDI because they will set you back a lot more than the dealer.
