Results 1 to 10 of 10
    May 2018
    Default MK5 Golf 2.0 SDI
    Hey,
    Can someone help me and Stage 1 + EGR removed (if it possible) that file from my MK5 GOLF 2.0L SDI?
    model(2006)
    ecu (EDC16U1)
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    mod file +egr
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  3. The Following 3 Users Say Thank You to Ignasvw For This Useful Post:
    AVDigitale (27th May, 2018), Melo81 (27th May, 2018), NickC (27th May, 2018)
    May 2018
    Quote Originally Posted by Ignasvw View Post
    mod file +egr
    Hey, Thank you very very much for the help.
    The car is smoking in high rpm.. maybe you can hook me up with the same tune with EGR ON?
    Sent from my SM-G935F using Tapatalk
  5. The Following User Says Thank You to NickC For This Useful Post:
    Ignasvw (27th May, 2018)
  6. #4
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Quote Originally Posted by NickC View Post
    Egr is closed. Working egr will give more smoke. I can make smaller torque , its without turbo, more fuel will give more smoke
  7. The Following 2 Users Say Thank You to Ignasvw For This Useful Post:
  8. #5
    May 2018
    Ok my friend, if you can loss the smoke it will be The best!
  9. #6
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    From which rpm car smokes
  10. The Following User Says Thank You to Ignasvw For This Useful Post:
  11. #7
    May 2018
    From about 4500~5000 right on cutting.. but my friend here says this is normal smoke
  12. #8
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Its quite normal to smoke from 4.5k rpm
  13. The Following User Says Thank You to Ignasvw For This Useful Post:
  14. #9
    May 2018
    Haha ok my friend thanks alot
  15. #10
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    XD who want smoking tune?
    Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
    DSG TUNING
    DPF / EGR / TVA / SAI / Lambda
    Crackle map ( Launch Control + No lift Shift + Antilag )
    File Service
    PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
