Marelli MJet bit rail pressure
    TuningInside83's Avatar
    Dec 2016
    Italy
    Default Marelli MJet bit rail pressure
    I need address of single bit for unlock rail pressure on 1.3 Mjet 75 hp
    pike's Avatar
    Sep 2013
    there is a
    "$8F008";"Rail pressure threshold for torque limitation";"1x1" "16bit HiLo"
    current value 1700 bar
  3. The Following User Says Thank You to pike For This Useful Post:
    TuningInside83 (28th May, 2018)
    Dec 2016
    Italy
    There is invalid address...
    pike's Avatar
    Sep 2013
    Quote Originally Posted by TuningInside83 View Post
    Changed to correct.
  6. The Following User Says Thank You to pike For This Useful Post:
    carmageddon's Avatar
    Italy
    check it....
  8. The Following User Says Thank You to carmageddon For This Useful Post:
  9. #6
    Dec 2016
    Italy
