Results 1 to 12 of 12
    tvzmaj's Avatar
    Serbia
    Default How repair hibrid “transistor” on Opel HSFI-2.1
    What is the element? FET or IGBT?
    All pins are short-circuited on this element.
    I had a link and picture with a solution from Russian blog, but I lost it
    Did someone fix this?
    Edit:
    My mistake. This is GND
    From the computer is better seen. He tricked me iPhone
    You can delete this topic. Sorry.
    Edit:
    belgrade,serbia
    yes it is ground and transistor is igbt
  3. The Following User Says Thank You to vladanr For This Useful Post:
    tvzmaj (28th May, 2018)
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    what transistor burn?
    Aug 2018
    East Pole
    Quote Originally Posted by vladanr View Post
    Igbt, nfet. No diode antiparallel inside. Good luck!
    For ignition coil IGBT N Channel 300V 10A min.
  7. The Following User Says Thank You to crisvermex For This Useful Post:
    tvzmaj (17th August, 2018)
  8. #6
    bytemans's Avatar
    Dec 2010
    Bulgaria
    Default transistor
    IRGS14C40L exteral
    Never say it can't be done , never say ready, before it is too !
  9. The Following 3 Users Say Thank You to bytemans For This Useful Post:
    Hayssam1 (16th November, 2020), mexanico1971 (3rd June, 2023), tvzmaj (30th March, 2019)
  10. #7
    stanislav georgiev's Avatar
    Oct 2014
    България
    I did it with transistor lrgs 14cl40
  11. The Following User Says Thank You to stanislav georgiev For This Useful Post:
  12. #8
    Oct 2014
    България
    I did it with transistor irgs 14cl40
  13. The Following 2 Users Say Thank You to stanislav georgiev For This Useful Post:
    Hayssam1 (16th November, 2020), tvzmaj (30th March, 2019)
  14. #9
    Aug 2018
    East Pole
    Now i see that the man had problems on all mosfets. The picture links that verry well. On the other side of discussion... How the * can you repair an ecu and leave an external "3rd little hand" to hang like a dog in the owner's leash? For Christ, put it inside the ecu!
  15. #10
    Oct 2014
    България
    Dude, you're thinking wrong. The transistor is glued on the inside of the lid, then the ECU is closed.
  16. #11
    Aug 2018
    East Pole
    Quote Originally Posted by stanislav georgiev View Post
    I was referring @byteman's job https://www.digital-kaos.co.uk/forum...6&d=1553879389
  17. #12
    bytemans's Avatar
    Dec 2010
    Bulgaria
    there is no mounting space inside with enough cooling area. the outside lead and sufficient moisture protection is ideal for this ecu. if you have a working version of a repair with a transistor inside, please send photos.
