I have had to revert to using a DM500-C with commando 15.1e image.
I powered the box on and was able to view several channels ok but since I did the last scan a large number of channels have moved.
So I did a new scan having setup my location as before (Lichfield) 00015, 642250, 6887. After a few seconds the scan failed with channel not available and the image recovered the bouquets. However after doing a brute force which did not find anything the image could no longer recover the bouquets. Further attempts at a scan resulted in No valid Bouqets found. I know my scanner and connection are good as I could orginally view a range of channels. There is no other nearby local area that I can try
