Results 1 to 14 of 14
    Dec 2016
    Default Seat ibiza 6L 2006 Magnet Marelli read PIN or make IMMO OFF
    I have a problem with Seat ibiza which after draing the battery to 0V have lost immo synchronization and does not start.
    I need IMMO OFF or read pin.
    I tried to read pin with Carprog via OBD but get security acces error. But Carprog connects with instrument cluster and reads fault.
    When I tried to take out dash and connect it via OBD but on bench i cannot connect even for faults..
    I found pinouts but it says that this dash is CAN line. but carprog use 10400 bps that i think is K-line speed.
    Dash number is:
    6L0920823B
    Where ther on EEprom is PIN stored? On which Eeprom and haw to read it?
    I see two eeproms:
    6250g
    2903 E2546
    but do not know what kind are they.
    2903 E2546 have tried to read as 95640 but read with errors
    >>Genuine Winols, Swiftec, Ktag, Flex, x17<<
    >Diagnostic, Chiptuning, Dashbord<
    SxL'.xll's Avatar
    Oct 2017
    Flux island
    try this pin 41813
  3. The Following User Says Thank You to SxL'.xll For This Useful Post:
    kubuswujo (30th May, 2018)
    SxL'.xll's Avatar
    Oct 2017
    Flux island
    you cant connect with dash because is safe mode
  5. The Following User Says Thank You to SxL'.xll For This Useful Post:
  6. #4
    Dec 2016
    safe mode in car with OBD II
    Or safe mode on bench?
    will try now your PIN as i think you read it from ECU Eeprom.
    If it will be wrong where to read it from tacho eeprom?
    SxL'.xll's Avatar
    Oct 2017
    Flux island
    safe on bench
    If i helped you then please click Thanks and Reputation Button
  8. #6
    SxL'.xll's Avatar
    Oct 2017
    Flux island
    pin is in 93C86 on the dash
  9. #7
    Dec 2016
    pin 41813 - not working now will try to look for 93C86 on dashboard. But doesn not have this eeprom title on any of them probably it is named diffrent.
    Where is it on dash? Photos in first picture
  10. #8
    Jun 2014
    Hi, friend the pin code you can get by obd2, cause there is many kind memory 1 (encrypted 93c86) and 2 mcu, if you don't found eeprom 93c86 so this mean you can just get pin by obd2.
  11. The Following User Says Thank You to pouleddy For This Useful Post:
  12. #9
    Dec 2016
    i tryied to get pin by OBD2, have used CARPROg > Scurity acces error, used Autel Maxisys Pro, also get errors. Do not have Vag CAN PRO. Which will read it also.
    VCDS do not read. Digiprog3 also do not read it...
  13. #10
    Jun 2014
    Quote Originally Posted by kubuswujo View Post
    Friend, what do you mean not read? vcds can't read pin code, do you mean no communication by obd2 the dashboard? or ?. maybe cause you trying on the bench that why can't accept, try on the car, go to the dash and try use universal pin code 13861 and after adaptation 00 or try readapt key by this pin, maybe can accept.
  14. The Following User Says Thank You to pouleddy For This Useful Post:
  15. #11
    Dec 2016
    Dear friend I mean that i tryied on the car wit ecu and Dash connected to car.
    And Carprog and Autel both were not able to read pin code i have oryg Key and tried to adpat it using 41813 wrong code. ok will try one more to adapt it with 13861.
    the car stood 15 km from me so i have to drive back every time i try it.
    Thets strange that i cannot read pin code using CARPROG Online by OBDII. thats why i try to do it by desoldering the Eeprom
  16. #12
    Jun 2014
    OK friend, try by vcds the login 13861. your ecu don't have pin code, the pin just in the dashboard. any way can you take a photo of dash from back also and put it here?.
    i put here a photo, see if your dash same as this with Motorola processor MC9S12H256, you can read with a programmer and put the dump here to get pin code.
  17. #13
    Aug 2015
    BEHIND YOU
    Dash number is:
    6L0920823B
    I see two eeproms:
    6250g
    2903 E2546
    if you still have problem
    just use my magic file and you car will revive again
    good luck
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  18. The Following 3 Users Say Thank You to eliaselias For This Useful Post:
    capi (25th May, 2020), kubuswujo (30th May, 2018), tarowa (10th May, 2021)
  19. #14
    Dec 2016
    Quote Originally Posted by eliaselias View Post
    good luck
    This is an Ecu eeprom? Yes?
    Will try
