Lookin great. Just wait for more tools like this one. Hope many developers will copy that method and then price will be very fair
Here is my video and i suppose a review
https://www.youtube.com/watch?v=0i6XEWNmlTU
If i helped please press the thanks button
paulsta (30th October, 2018)
Hi to all
Today I received this tool and do some testing.
reset used key 868mhz e series- successful reset
cas4- reset milage to 0 - successful
cas4- read eeprom and flash BUT EVERY TIME DIFFERENT DATA. (when check with cas editor they still see VIN and KM) - unsecured
i will post readed files someone can check if is ok
Frm3 xeq384 - can read and write d flash, and that is all. CAN NOT write eeprom
UPDATE shortly
BMW FOREVER
fe7565 (19th November, 2022), lolo241 (11th November, 2018), phuckyall (7th November, 2018), PocketHero (8th November, 2018), trinicolin (7th November, 2018)
VIN WBAFW1105BC658232
2 kEYS
looks fine to me
yes but did you see difference between files? look the time. that files is from same CAS. I read it few times in row and every time is different. I think that just on one file I change millage
BMW FOREVER
What are you guys using to drive the interface?
I tried to install the app on a Galaxy S8 but the app does not even open, just crashes as startup.
My laptop does not see it through bluetooth built into laptop.
I have ordered the bluetooth dongle to see if that helps.
So far I have not been able to use this tool, bad start already.
im using, iphone 6, google pixle 2 xl
what os are you using?
I using Iphone X. thats happend to me. when they activate device and make autorization everyting works
BMW FOREVER
on PC have same problem. even now. they don't recognize device until I login and disconect LAN cable. doesn't matter if you are on wifi, if lan conect to notepad device dont see network. maybe that will fix on update.
today I have answare from tech support that will on some of next updates do eeprom write to frm. Any tool can do it. I dont understand that this tool can't
still don't have answare why when device read cas few times in row every time have different data.
FEM test in half- device read some data and see milage and VIN- dont have time to do proper test - here is files
BMW FOREVER
you dont need BT dongle. you dont need to sync like that. just do it first on phone and LOGIN then open on PC and login there. p.s. disconnect LAN cable fom PC
BMW FOREVER
I cant get it to connect to the pc at all
